Forum: Old versions
Topic: VDJ controller option and mapping
I just have a simple question that I cant really find a clear answer to. If you get the VDJ Controller option, does this mean all functions of the controller will work on VDJ8? I've seen lots of mapping issues. the controller in question Hercules DJ Console MK4 and the Numark Mixdeck Quad (as this comes with Seratto and I do not like that program at all) thanks greatly
geposted Tue 03 Feb 15 @ 10:35 pm
If you don't like the mapper, you can just install a custom mapper.
It's possible with a contoller licence, but not possible with a bundled LE licence.
Yes.
There are no mapping issues. Users usually want to change the pre-defined behavior of their controllers, and that's what you see on the forums. Not real issues with mappers.
Keep in mind that for two different controllers you will need two different PLUS licenses. Therefore you may want to consider purchasing a PRO Infinity license instead that has no limits ;)
What I'm mainly looking at is the numark mixdeck quad that I will use for a long long time and it comes with serato which I do not like at all and was wondering if this Controller woukd work fine with the DJ control option. That's pretty much what I looking for.
