Hi
I am broadcasting with version 8
the problem is, everytime I am speaking in mic to my listeners....I'm hearing myself in backvoice too!!
so its really annoying
how to disable that?
whats causing this?
Im using a good headphone set and my computer integrated mic is turned off
whats causing this?
geposted Thu 05 Feb 15 @ 7:09 pm
My guess is that you're experiencing latency, due to using a basic built in audio interface or external unit that's only intended for consumer use.
To eliminate latency (timing delays) you need to use a pro interface with low latency drivers (ASIO on PC).
geposted Fri 06 Feb 15 @ 8:59 am
thanks for your answer
but im not sure to understand correctly.
you mean my soundcard is not forthat use?
geposted Fri 06 Feb 15 @ 11:19 am
this is my audi screenshot
geposted Fri 06 Feb 15 @ 11:27 am
geposted Fri 06 Feb 15 @ 11:28 am
I think he means your audio setup, not the options, try clickin on the audio symbol(top left) and post another screenshot
mfg
ray
mfg
ray
geposted Fri 06 Feb 15 @ 1:55 pm
here is screenshot of the Audio setup :)
waiting for help!
thx
geposted Fri 06 Feb 15 @ 2:16 pm
To explain further - unless your computer is costom built for pro audio use, the built in audio interface (sound card) will not be suitable for pro use, such as applications requiring low latency, like DJing or broadcasting.
You need to be looking at upgrading to something designed for pro audio use.
geposted Sat 07 Feb 15 @ 9:02 am
ho ok, well im using a laptop so i will buy a desktop made for that then :) thx for the help!
geposted Sat 07 Feb 15 @ 11:31 am
No need to buy a desktop - just get yourself a good external USB audio interface.
geposted Sat 07 Feb 15 @ 11:38 am
