OK, I have finally managed to replicate this...
geposted Tue 17 Feb 15 @ 1:24 pm
Loop Out v1.2 is now available and should fix the freeze/crash issue and possibly locodogs issue too.
I haven't updated vloop out yet.
geposted Tue 17 Feb 15 @ 2:10 pm
VLoop Out updated to v1.1 with the same fixes applied.
geposted Tue 17 Feb 15 @ 2:23 pm
Works better thanks a lot for fixed ;)
geposted Tue 17 Feb 15 @ 4:59 pm
Im glad you found the issue i was thinking I was alone on the glitch thanks for fixing it
geposted Tue 17 Feb 15 @ 6:59 pm
Thanks loco dog always very helpful
Working well on windows, no crash nor over gain ,
just one loose end,
You need to the query the actual loop length & state before the FX sends its "loop X" command, on some occasions the command isn't needed.
If the loop out FX is set to length 1, and if the track is already in a loop 1 when you press the fx on then the loop is turned off
I know I'm pointing out points for idiot proofing....
geposted Wed 18 Feb 15 @ 3:55 am
Thanks for letting me know :)
geposted Wed 18 Feb 15 @ 4:19 pm
Hi,
I updated to the new version of the plguin and now it doesn't seem to loop out, it just creates a loop and then continues playing? Before I updated it, it worked fine! Thanks!
geposted Thu 02 Apr 15 @ 4:02 am
