Discussion about Gemini GMX
geposted Fri 06 Feb 15 @ 12:55 am
Is there a way to record sets using the GMX and VDJ8?
I just purchase this unit, but I'm not being able to record, all I get is this mesage "could not open file for writing".
Any ideas or solutions on how to record my sets would be kindly appreciated.
Thank you.
Thank you.
geposted Fri 06 Mar 15 @ 10:40 am
Not related to the skin, so this is not the best place to post and get support.
Anyways, probably a permission issue or a write-protect issue on your Hard Drive ?
Can you try to record on a file on Desktop ?
Have you properly set the filename/filepath that VDJ will use ?
geposted Fri 06 Mar 15 @ 5:34 pm
This skin works perfectly with the Gemini G2V Controller.
geposted Sat 09 May 15 @ 2:30 am
Can't download Gemini Skin from this link: http://www.virtualdj.com/plugins/index.html?category=1&filter=4&page=3&search=&sort=downloads
Download button is not clickable... just a picture
geposted Fri 14 Jul 17 @ 3:58 am
Not all skins are available for home use. Some are for license holders only.
You need to purchase a license before you can download that skin.
geposted Fri 14 Jul 17 @ 9:45 pm
Dont see a Gemini skin in the link u provided, but the Gemini GMX skin (link from 1st post) can be downloaded by simply registering your LE keycode (serial) to your account. I suppose, you have the Gemini GMX unit to ask for such a skin, and GMX comes with VirtualDJ LE, so you should have one.
geposted Fri 14 Jul 17 @ 11:29 pm
bonjour je recherche le logiciel qu'il me faut pour installer virtual dj pro sur gemini cdmp7000 ? est ou le trouver ? jai payer est je ne ses pas ou allez pour récuperer mon logiciel svp aider moi
geposted Sun 29 Oct 17 @ 5:02 pm
