Forum: Old versions
Topic: Not able to save recordings
Hello,
I'm using version 7,
The problem is:When I'm recording some mix, the mp3 file doesn't appear.I have set location, tried different locations, no differences.Any suggestions?
geposted Fri 06 Feb 15 @ 2:19 am
Not sure if it is a restriction of the home version or you need the Lame encoder installed.
http://lame.sourceforge.net/
Just copy it to a location and give VDJ the path to the file.
on V7 Home, recordings should be only avaliable as wav.
