Forum: Old versions
Topic: External mixer via USB problemudled
Hi all,
I'm having an issue configuring VirtualDJ LE which came bundled with my new American Audio MXR14 mixer which has it's own built in sound card.
Initial setup was ok then I decided to try the 20 day Pro trial which has now expired. Since then I can't get the external mixer option to stay set in the sound setting dialog window. I select 'external mixer' & 'ADJ ASIO' click apply & OK but when I re-open window the settings have reverted back to 'single output' & 'simple' sound card.
I've tried different software (Mixx) & this works fine again via USB. I've also re-installed the software.
Anyone got any ideas?
PS This only happens if the external mixer option is selected
All the best.
geposted Sat 07 Feb 15 @ 7:26 am
Your VirtualDj LE version is designed to work with "internal" mixer mode selected, not external.
That's why the settings revert after 10 minutes
