had to renew my mac after a disaster , but most of my songs wot play out of my saved history , iv tried downloading the play list fixer but it wont down load properly or install
HELP
HELP
geposted Tue 10 Feb 15 @ 11:37 am
If you moved the location of the files, that will cause this to happen. Make sure the files are in the exact same place as before. If not, you have to re-add/re-scan your files.
geposted Wed 11 Feb 15 @ 2:31 pm
yer I know that but in the down loads ther is a add on called
PLAY LIST FIXER AND IT STATES THIS
The VirtualDJ Playlist Fixer opens VirtualDJ database and scans all playlists for missing files.
Using the database information, it will fix your VirtualDJ playlists by finding the new location of moved files, and best possible matches for renamed files.
This tool also fixes VirtualFolders and the History (Tracklisting) playlists.
Version 1.3: Now has a Mac version
BUT when I down load it to mac it wont load in , so frustrating
geposted Wed 11 Feb 15 @ 9:24 pm
