I donated via Pay Pal to activate skin creator, but it won't activate. Tried to contact the creator, Jeremie. But, not getting a reply. Any help?
Does anyone know if we will have a tool like this for VDJ8?
geposted Fri 13 Feb 15 @ 12:49 pm
The skin creator tool only works for V7 skins and previous.
Babis has a new tool for V8
https://virtualdj.com/forums/187973/VirtualDJ_Skins/_BETA__Skin_Builder_-_Version_8.html?page=1
geposted Fri 13 Feb 15 @ 3:11 pm
You could still make a skin in Skin Creator and run it in VDJ 8. Yes it's designed for VDJ 7 but the skins will still run in 8.
OTOH the Skin Builder skin is not really a creator - more a way of rearranging the elements djdad has provided.
geposted Fri 13 Feb 15 @ 3:21 pm
I tried, but can't seem to use skin creator at the moment... It crashes and won't let me update on startup. Sighhhh
I wanted to make use of the alpha channel that PNG supports. So, skin creator doesn't seem like the likely choice right now.
geposted Fri 13 Feb 15 @ 8:12 pm
