I successfully exchange the Logo (for video output) with my own as I used with previous not VDJ software before.
Even if I choose "large" as size it is too small for me. I try to increase the image size, but this doesn´t matter. The size with "large" is always the same. Also "right-top" give still borders to top and right which is not optimal for me.
Is there any way or plan the change this?
I would need a size and pos in pixel or at least the possibility to increase the size and to pos it in the upper right corner (no border).
geposted Sat 14 Feb 15 @ 10:20 am
For the size, you can manually enter a number which is the percentage of the screen, so 50 would make the logo 50% of the width of the screen.
It is currently not possible to further customize the position of the logo though.
geposted Sat 14 Feb 15 @ 10:30 am
okay, thank you I will try to use that so far. For the size I find out values from 0.1...1.0. I found no difference for 10 or 50.
Even with bigger size I got borders to the corner.
Is it worth to list this as feature request or is that already a wish?
geposted Sat 14 Feb 15 @ 11:45 am
sushifix why don't you use the ShowLogo8 plugin?
geposted Mon 16 Feb 15 @ 10:55 am
okay, great. This work as I need it.
Thank you!!!
Thank you!!!
geposted Mon 16 Feb 15 @ 12:28 pm
Your welcome! I thought about it when i first saw your post but i believed that you somehow didn't want to use it...
geposted Tue 17 Feb 15 @ 2:52 am
