Forum: Old versions
Topic: Additional controller for sampling and effects
Hi!
I want to use an additional controller (only with pads) toghether with my Numark N4 so I can mangage sampling and effects etc. in an more easier way.
My first question, Is it possible to have two controller at the same time in Virtual DJ 8 to apply this type of setup?
Next question, If yes, I know Novation Launchpad is the type of controller I looking for but will there be any other suitable controller for this, maybe with less pads than Novation LaunchPad.
Greatful for feedback.
geposted Sun 15 Feb 15 @ 5:29 am
Yes, you can use two controllers.
How many pads do you need? Products you may find suitable:
Akai LPD8, MPD18, MPD26
Korg PadKontrol, NanoPad II
IK iRig Pads
Vestax Pad One
Arturia BeatStep
Onmitronic Pad-12
Reloop Neon
Great!
Suitable for me should be 15-20 pads.
I will look closer on these Products you mention.
Thank´s for the tip!!
Furthermore, do you even know if the skin for Ipad is suitable for this kind of use?
Hey there,
I am also wanting to find a set of beat pads for my Numark Mixtrack Pro 2. I found the iRig Pads at Sam Ash the other day, but before I could buy it I needed to see how it works with the samples and effects.
If it's midi it can be mapped however you wish.
