Forum: Old versions
Topic: Controller Mapping syntax for Version 8 (under construction)]
Any estimate on when the "Controller Mapping syntax in Version 8 (under construction)]" will be finished? I know you guys want to make sure it's thorough and correct before releasing but I really need this for a couple of mappings. Plus the sooner you release, the sooner we can test it out for you guys :)
geposted Mon 16 Feb 15 @ 1:11 pm
Nothing significant is changed compared to version 7.
Is there something that you need to ask about the structure of the mapping files ?
One difference, as far as i can recall...
Description="" is optional. The name of the mapping file you see in the Controllers tab is taken from the Device file (definition), so if you want to upload/create a custom one and provide a "special name, just name the mapping.xml file with the name you wish to provide.
can I use virtual dj 8 with reloop beatmix 2 controller?
@PachN thank so much dude! <3
I can't play with reloop beatmix 2 in virtual dj without paying?
Yes, you can play - for 10 minutes at a time.
Then if you decide you want to use VDJ permanently, you can either pay a monthly subscription or buy an Infinity license. These will allow you to use VDJ professionally.
If you're only going to use VDJ at home then you can buy a controller license, which is cheaper but does not permit professional (earning money from DJing) use.
