Forum: Old versions
Topic: Timecode signal passing through no matter what
I have been trying to set up timecode vinyl using a single Technics tt using both VDJ7 and VDJ8. With both programs, the timecode signal passes through to my mixer. I am using an Asus G74SX with 16gb ram, a Hercules DeeJay Trim for the usb phono connection and into a Yamaha MG12X mixer. I have tried both 1&2 and 3&4 on the Herc and I have calibrated and recalibrated several times in both 7 and 8. I have made sure Timecode Passthrough is OFF. The program is getting a great clear signal, I am just hearing it in my mix. Any suggestions?
geposted Tue 17 Feb 15 @ 12:57 am
Check your Hercules Trim driver settings...
You should MUTE the inputs... ;)
Thanks for the reply. I have tried MUTING the inputs from the Hercules, and then the VDJ doesn't get the timecode signal. Am I missing something? Is there a specific setting in the TRIM? Should I be using ASIO or WDM?
