Forum: Beta Builds Regression Bugs
Topic: BUILD 2156
-fix %Pcamelot to change as pitch changes
-Export option for playlists added to copy files all the files in the playlist
-Sampler output deck stored in config
-Sampler option added to apply deck effects to sampler output
-Slip disabled on loading new track
-Scratch wave default cue marker color made more clear
-Fix touch-screen difficulty to select multiple files using ctrl or shift
-Fix sidelist/automix getting cleared when updating
-Fix midi reconnection issue that could cause controller leds to stop working
-Year now stored when saving mp4 tags
-fix shatter transition block size setting whilst not selected
-fix skin <window> element opening behind main VDJ interface on Windows
-improve support for older capture cards in camera plugin
-Fix sampler sound issue when Apply Deck Effects is active
geposted Tue 17 Feb 15 @ 2:03 pm
Sampler output on decks is pre eq/filter, but still post fx. Unless I'm doing something wrong.
I even tried non beat dependant ones like filter.
Confirmed. I used sampler_options on a custom button to get the menu, selected deck 1 as the audio output (which then makes the Apply Deck Effects option appear).
Clicked on that and the effects don't do anything - the channel EQ and filter does.
BTW why doesn't the channel metering work when the sampler is playing through the deck (unless the new option is selected)?
Same here. It was working with the test builds we tried, so i guess something went wrong and will be fixed in next build.
It should, i guess another bug for next build.
Is there (or will there be) a script action for applying effects/EQ to the sampler output?
Would be good for having the ability to apply them through some sneaky skin code instead of needing to use the mouse to reach a menu option.
there is a setting to toggle this, so i believe you can already use the setting action.
Ah so there is - samplerApplyEffectsOnDeckOutput. Catchy name! :-)
Maybe one day we'll be able to set each individual sample slot to send its output to a separate deck, so we could make use of VDJs 99 decks
and set up VU meters, EQ and FX for every sample. Imagine a row of sample pads, each with its own "channel strip"...
The changelog isn't displayed before update on Mac
thanks for this one seems great so far and the database info comes with super.........
thanks so much dev team
There is a problem with Mp4 Tag, before in 2073, some mp4 can't be tagged, but now with 2151 can be tagged without problem, sound solved but now these file lose Bitrate field.
Image attached
Can we get the export function for the filter folders also
you gentlemen rock. Appreciation!
