Forum: Old versions
Topic: Waveform not loading
Hello,I have just upgraded my virtual dj pro to the latest version compatible with my dj controller numark mixtrack pro 2 quad deck(7.4.2).In every version that I uprade, waveform does not load for some songs.Why?
geposted Wed 18 Feb 15 @ 7:53 am
What is the length of the ones that do not load?
There is a setting that limits it if the file is to long.
Not sure if its adjustable in th LE version or not.
i have a song which is 4 mins long whose wavelength is not loading and a song which is 6 mins long whose wavelength is loading,so i dont know whats the problem.
Are they both the same file format?
What happens if you analyze the song and then load it into a deck?
Brother can u just help me in telling how to analyze a song?I will try that once.
Done!Thanks I just analyzed all songs and the problem was solved!
