Hi
I have MacBook Pro With Windows 7 64BIT + DDJ-SZ.
All Is Ok with VDJ 7 For Many Years.
Now
After Installing VDj8 I Have A few Serious Problems.
I Will Open A Topic For Each So It Will Be Easier To Solve :)
When I Configure VDJ8 Everything Seems To Comply To My Wishes But When I Close The Software It Forgets All The Settings I Configured...
Like Starting Folder, Effect Order, Slip Mode Etc...
I Checked Permissions All Full For The Folders In VDJ.
I Uninstalled Cleaned The Reg And Still The Same.
The Only Time It Will Save The Configuration Is If And When I Delete The settings.xml So It Will Save My Config Only Once With no Future Changes Possible.
The Same Is For effects.
I Configure Any Effect and it will remember my setting up until I close the program.
Anyone Can Give Me A Solution?
Thanks
Now
Thanks
geposted Thu 19 Feb 15 @ 5:36 pm
After Further Investigating The issue
I Found That If I Disconnect the Controller (DDJ-SZ)
The Configuration is Being Saved...
Any idea?
Any idea?
geposted Sat 21 Feb 15 @ 8:02 am
So just to understand, if for example you add a Column (Field) in the Browser ..e.g. Comment, and then you close and relaunch, the extra field is not there ?
Or if you change skin, the same skin doesnt come back on relaunch ?
Or is there an issue with just some certain settings ?
geposted Sun 22 Feb 15 @ 6:29 pm
didn't try the skit thing...
but if I add a Column or change any configuration ant then restart the program
then yes it doesn't save it.
if I disconnect the controller then all ok :)
crazy problem...
I cant make it remember simple things...
crazy problem...
geposted Mon 23 Feb 15 @ 6:18 pm
Can you check if closing VirtualDJ with the DDJ-SZ connected, no virtualdj.exe appears as running in Windows Task Manager ?
Can you also make sure that the DDJ-SZ sound card is not the default sound card for Windows ?
One other thing.
enable the setting CreateMidiLog (from the Advanced Options) and do a launching cycle of VirtualDJ (close-open-close)
Post here the content of the Log Report.txt you will find in Documents/VirtualDJ folder
One other thing.
geposted Tue 24 Feb 15 @ 11:08 am
As For The VDJ Process: No i Ita not Running After Closing the Program.
Here Is the Log:
Audio device found: name="Digital Audio (S/PDIF) (Cirrus Logic CS4206B (AB 39))" vid="0x1013" pid="0x4206"
Audio device found: name="Speakers (Cirrus Logic CS4206B (AB 39))" vid="0x1013" pid="0x4206"
Audio device found: asio="Pioneer CDJ ASIO"
Audio device found: asio="PIONEER DDJ-SZ ASIO"
Audio device found: asio="PIONEER DJM-900SRT ASIO"
Midi out device detected, name:Microsoft GS Wavetable Synth mid:1 pid:27
MIDI Device Identifying: \\?\usb#vid_08e4&pid_0191&mi_01#7&1be1b2a7&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global (in:0 out:1)
MIDI Device Identified by PID/VID: \\?\usb#vid_08e4&pid_0191&mi_01#7&1be1b2a7&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global
MIDI Device Identifying: Microsoft GS Wavetable Synth (in:-1 out:0)
Midi Out Closed (Microsoft GS Wavetable Synth)
MIDI Device Not Identified: Microsoft GS Wavetable Synth
Midi In Closed (\\?\usb#vid_08e4&pid_0191&mi_01#7&1be1b2a7&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global)
Midi Out Closed (\\?\usb#vid_08e4&pid_0191&mi_01#7&1be1b2a7&0&0001#{6994ad04-93ef-11d0-a3cc-00a0c9223196}\global)
just for the record in order to activate the CreateMidiLog i needed to disconet the SZ exit and the did the cycle as you asked...
Here Is the Log:
geposted Fri 27 Feb 15 @ 4:02 am
One more thing...
after updateting to the latest beta/
when loading a track the slip still stay on.
any idia?
any idia?
geposted Fri 27 Feb 15 @ 4:24 am
Can you See Anything In The Report?
geposted Tue 03 Mar 15 @ 8:34 pm
