Topic: VDJ Upper WaveForm Transperent.
Hi
I have MacBook Pro With Windows 7 64BIT + DDJ-SZ.
All Is Ok with VDJ 7 For Many Years.
Deck 2 Colred RED And Deck 1 Is Colored Blue.
When I Load A File Into Deck 2 I Cant See It In The Waveform Window..
I Know Its There Its moving Some What Transparent In The Background I can add the extra GridLines and that I Can See well.
this Only Happens With The VDJ8 6 Or 4 Deck Skin (Original).
I Tried To Change Resolution (windows), Install / Uninstall VDJ8.
Anyone?
geposted Thu 19 Feb 15 @ 5:47 pm
I would suggest to update the drivers of your video card.
Is the waveform of deck 2 visible if you select the Inverted wave from the Top WAVEFORM menu/button ?
Any chance the Aero Graphics is disabled ?
What happens if you select Deck 2 by clicking on the "B" (or use TAB key) at the upper right cornor of the skin?
Does the deck 2 waveform come to the front?
No Deck 2 Always Transparent And I Can Hardly See It No Matter What I Do...
As For The Drivers... I Use A MacBook Pro 17" With Windows 7 On Boot Camp So its Not That Easy To Update Drivers...
But any Other Skin Works Fine and on vdj7 all 100% also.
Please try downloading the install pack again.
https://virtualdj.com/download/
This contains any changes to the skins - which aren't automatically updated.
If this still doesn't help then it must be a Graphics Driver issue as already suggested.
Good call - I forgot about that link.
I'm happy to draw your attention to that page once again.
:-P
Thanks For Your Help :)
The Solution Was To Update The Graphic Driver...
Thanks Again
