Forum: Old versions
Topic: MXR19 Mapping
Hi, I have the MXR19, just got it.. I got it loaded however I want to use with 4 decks and I cannot assign the levels in order. The default levels has 1,2,3 out of order. 4 works as design. I called ADJ support and they said I cannot. Don't understand if it's a midi controller you should be able to assign what any button or level does..
Gonna play with it some more, but wanted to see if they are any ideas..
geposted Thu 19 Feb 15 @ 9:35 pm
In order to use it as a 4 decks controller the first step you should do is to switch the unit to "controller mode"
After you do so you should go on "controllers" tab on settings and change the mapper from "default Mixer Mode" to "default Controller Mode"
Finally you should use the drop down box to change the mixer order from 3124 to 1234.
PS: It's impossible to use the unit as a 4 decks controller in hardware mode and it's impossible to change the channels used for MIDI / USB data in hardware mode.
