Ddj-sz and vdj8.
When loading track to deck 2 the platter indicator on the controller is not moving....
After loading a track to deck 1 then deck 2 start to work fine.
Any Sugestion?
Any Sugestion?
geposted Sat 21 Feb 15 @ 2:21 pm
Are you using the factory default mapping or some custom one ?
geposted Sun 22 Feb 15 @ 6:25 pm
I had the same problem last night, did a controller reconnect and resolved... Default mapping + the suggestion from DJ Dad for the vinyl mode (problem that you must press the vinyl mode twice to get it right in VDJ)
geposted Sun 22 Feb 15 @ 6:51 pm
