Forum: Old versions
Topic: only 1 deck playing
just purchased subscription to pro8 but only 1 deck is operating when I use the program...other decks have no sound coming out?
was I supposed to enter a code or something to unlock use? there was no prompt to do so.
geposted Sun 22 Feb 15 @ 5:49 pm
If you have multiple outputs, then you can set one deck to come out of channels 1 and 2, and the other to come out of 3 and 4, for example. Have you checked the audio settings to make sure it's not?
Yeah a screen shot of your audio settings will help.
