Forum: Old versions
Topic: Need Down grade version for mac
hi
I need a downgrade virtual dj for my mac please, the one i got when i purchase a gemini controller can only work on a mac running at 10.5 ! so the advice giving from the cd was to contact virtual dj and get a downgrade version, i also scratch away part of the serial numbers in the middle, any assistance would be greatly appreciated Thanks
geposted Tue 24 Feb 15 @ 3:34 pm
I'm so sorry but we do not have a simple solution for you.
I only can advise you to buy the Pro Infinity Version8, because we give to our Pro user also the Version7 Pro Full as a extra download.
The sad thing is, we can't give away new VDJ LE (Controller provided) keys.
So if you would still want to use the controller provided version/key, i only can advise you to contact the Gemini and ask for replacement key.
What version of OS X are you using?
Your post seems to imply that it's older than 10.5?
