I want to be able to trigger the samples and effects in vdj 8 without having to do it via mouse/keys. I have been looking at the sp1 which has been designed around serato but says it can be programmed to work with any other dj software.
Does anyone use/know if the sp1 can be used with vdj8?
Thanks.
Thanks.
geposted Wed 25 Feb 15 @ 11:36 am
Yes it can, a forum regular has one, and it is supported natively.
geposted Wed 25 Feb 15 @ 1:04 pm
Operation manual for the SP1
https://virtualdj.com/documents/Pioneer%20DDJ-SP1%20VirtualDJ%208%20Operation%20Guide.pdf
Effects are explained in pages 5 to 8
geposted Wed 25 Feb 15 @ 2:58 pm
Cheers for that, placed my order should get it in a couple of days.
geposted Thu 26 Feb 15 @ 5:02 am
