Removing tracks from a playlist will only persist when the playlist is on its main sort order.
Explanation:
- I sort my playlist by BPM or title, then I remove a song from it: it looks like it worked. Then I select another playlist and back on the first one again: the song is there again. The XML is untouched.
- I sort my playlist using the "reset sort order" button and then I remove a song from it: it works as expected.
MacBook Pro Late-2013 Retina 13", 16GB RAM, i5-4258U CPU, 256GB SSD.
File and folder permissions are OK, no "big" apps running, no Wi-Fi, no Bluetooth, no network shares, no anything...
I'm 100% sure it's a VDJ bug.
Explanation:
geposted Sat 28 Feb 15 @ 5:32 am
