Hi,
I get this crash when using a Odyssey ColorKey Keyboard. I even setting to Ignore in Mappers. I just want it as a Keyboard not use any mappings.
Any clue with this?
Problem Event Name: APPCRASH
Application Name: virtualdj8.exe
Application Version: 8.0.2162.0
Application Timestamp: 54eedc08
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.18247
Fault Module Timestamp: 521ea8e7
Exception Code: c0000005
Exception Offset: 00033e3d
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 3260
Additional Information 2: 3260c818896bf912f35a700ac9ed8030
Additional Information 3: 670f
Additional Information 4: 670f435c6326f15d281dde0310895587
Any clue with this?
Locale ID: 1033
geposted Sat 28 Feb 15 @ 12:24 pm
Also got this when the keyboard was not plugged in.
I used my mouse to click a song to select it and then use the Load dial to load it to the player.
Exception Offset: 00033dff
Locale ID: 1033
Locale ID: 1033
geposted Sat 28 Feb 15 @ 12:32 pm
Anyone have an idea with this?
geposted Wed 04 Mar 15 @ 6:04 am
Crash occurs even if no controller is connected at all ?
Happens with all of your files ?
geposted Wed 04 Mar 15 @ 3:09 pm
No. Only whencontroller in.
geposted Wed 04 Mar 15 @ 6:11 pm
Is the "factory default" mapping the one you re using ?
Can you also try with the Default 2/4 decks skins (if not already use those) ?
Does it happen with all of your files ? Same crash with both audio and video files ?
If only with some specific, could you upload one of them and pm me the link ?
geposted Wed 04 Mar 15 @ 10:21 pm
Hi, Just PMed you.
geposted Sat 07 Mar 15 @ 5:54 am
Hi have you gotten a chance to check it out yet?
Thanks
Thanks
geposted Sun 08 Mar 15 @ 9:04 pm
Hi,
Really hate to be a pest here. Did you receive my PM with link to files and demo video of crash? Were you able to replicate this?
Thanks!
Thanks!
geposted Sat 21 Mar 15 @ 5:38 am
By chance, would not doing this cause this issue:
Please ensure that the MIDI controller setting does not allow [KEY
LOCK] button to be lit. If the [KEY LOCK] button is lit, please switch
the setting to unlit.
geposted Sat 21 Mar 15 @ 6:02 am
Actually it is unlit
geposted Sat 21 Mar 15 @ 6:10 am
DJDAD, did you receive the link I sent you to download the files I was using?
geposted Fri 27 Mar 15 @ 5:06 am
Files dont crash here.
geposted Fri 27 Mar 15 @ 12:50 pm
I know this happens when I use the button to select a song with.
What ideas do you have?
geposted Fri 27 Mar 15 @ 12:55 pm
Are you sure you are using the factory default mapping ?
Sorry, can you please explain this ? Where do you get/read this ?
geposted Fri 27 Mar 15 @ 12:57 pm
The vdj guide for this controlle or the operation manual by pioneer.
geposted Fri 27 Mar 15 @ 1:00 pm
it would help if you point me the page Number.
geposted Fri 27 Mar 15 @ 1:05 pm
I will when I get back. Is there an option for you to remote in and troubleshoot that way?
geposted Fri 27 Mar 15 @ 1:14 pm
geposted Fri 27 Mar 15 @ 4:54 pm
Even though i dont see the text you have posted in the PDF manual, i assume that you are referring to the "Serato mode" from Utilities.
VirtualDJ 8 uses the Serato mode, regardless the setting in Utilities, same as the Serato software does.
So your issue should not be related to this... Or is it ??
geposted Fri 27 Mar 15 @ 5:25 pm
