Greetings ....hey I use to use DJ with virtual vinyl time codes ...I want to start video mixing using the virtual vinyl software I use to use for time code ..I want to use a controller that is compatible with this software ..I looked on the softwares preferences under remote control and it shows what controllers work with it..the thing is that those controllers on it are very low end controllers..I want to get a mid grade to top end controller any suggestions??
geposted Mon 02 Mar 15 @ 12:39 am
