Forum: Old versions
Topic: Video use...frustrated!!!
OK, this should be simple as in VDJ7. How do you move the video window around the screen? When I open it I can re size but the top of the window is somwhere up off the top of the screen so i can't click on it to move it or close it!!
Also can someone tell me where to select that I want the video to show on a projector screen when i connect to an in house projection system? In 7 in configuration settings you can see what is connected. Where is this in 8???
Get this sorted and I may even try it Live, but up to now and reading many many other comments it's still 7 for me!!
Thanks
geposted Mon 02 Mar 15 @ 6:09 am
Right click on the master video display to list the available outputs. Oddly, this is not mentioned in the manual.
Great thanks!....that explains why I couldn't find it!
So, VDJ, best add this reasonably important line into the manual on your next update me thinks!!
