Forum: Old versions
Topic: Transferring Cue points
Hey how can i get all my cue points from virtual dj 7 had the numark edition to my virtual dj 8? I know its suppose to be automatic but it didn't happen to me. Any way to fix this? Have thousands of songs already with the cue points set up, dont want to have to do it all over again!
geposted Tue 03 Mar 15 @ 9:10 pm
delete your V8 database, connect all external drives and boot V8
I tried it but to transfer from Numark Cue to Virtual dj its not working can you help me ASAP
What is the name of your Numark database?
hola mad man, sometimes very clever peeps are pretty (I do'nt want to say it)
as an old Numark CUE user may I suggest that you go to your Numark Cue folder(Documents) and copy your db(virtual database V6) into your VirtualDJ(Documents) filepath thingy.
then VDJ8 will find it and read all your stuff into the new db.
VirtualDJ8 doesn't talk to Numark CUE because it's in another directory, but if you move the db across it should all work out allright.
best wishes
ray
CUE pro user since 2005!
