If you try and copy files to another folder using the "File Operations > Copy To..." and it encounters a missing file from the database, the copy process stops. It would be nice if it just skipped it.
This happens usually if I create a filter folder of say 1000 songs, and want to copy to another location. The copy process just stops or doesnt work if it encounters a single missing file.
geposted Tue 03 Mar 15 @ 11:46 pm
