Topic: TouchWheel BackSpin Delay [FIXED] - Page: 1
Ok when I have "touchwheelbackspin" set to "YES" theres a small delay when I let go of the jog (using Pioneer CDJ 850's) yet when I have it set to "NO" the delay is gone BUT I can no longer do back spins.
Is there anyway this can be looked at and tightened up?? For anyone that scratches this is no good.
I want the backspins but this delay has to go. Please help or is there some other settings I need to change?? The delay is not there in SSL/SDJ so I know its something in VDJ.
geposted Wed 04 Mar 15 @ 9:28 pm
Make sure you start to move the jogwheel forward just before releasing.
geposted Thu 05 Mar 15 @ 3:04 am
Really? Pushing forward on a cdj is something I had to break myself of coming from vinyl. It just doesn't feel natural that way.
Can this not be changed or tightened up?? Even when using them with timecodes I don't have to push forward.
geposted Thu 05 Mar 15 @ 6:14 am
After a conversation we had with Adion, he agreed on adding a parameter or by default ignore jogwheel notes if the playing speed is reaching very low, which will resolve what you have requested.
However, it is not on the high priority list, so not sure when will this feature will come. Hang on, but dont bump ! lol
geposted Fri 06 Mar 15 @ 1:56 am
Do you see any difference/improvement with beta build 2171 ?
geposted Mon 09 Mar 15 @ 10:54 am
I'll be home in about an hour and I'll test it out.
geposted Mon 09 Mar 15 @ 4:08 pm
Worse then before.......
geposted Mon 09 Mar 15 @ 8:07 pm
Tear Em 'UpPRO InfinitySenior ModeratorMember since 2006
Confirmed VCI300
geposted Mon 09 Mar 15 @ 8:37 pm
I honestly don't ever remember this happening with VDJ 7?
Gonna have to hook everything up an try it out again cause if 7 ends up bein better then that's the direction we need to go back to.....
geposted Mon 09 Mar 15 @ 9:45 pm
I am sure the Team will take a look and fix. Thats why we call some builds as "beta" btw ;)
Can you define "worse" ? More delay instead of less ?
Because what i get here is not more delay, but certainly no big difference.
PS. I am not good in scratching :)
geposted Tue 10 Mar 15 @ 10:22 am
A lot more delay to the point if it not even being useable for me......
geposted Tue 10 Mar 15 @ 11:26 am
Much, much better 👍 I can work with this! Talking about the newest beta also.
Maybe another 10-20%?? 😳
geposted Tue 10 Mar 15 @ 6:48 pm
Still would like to see this improved on even more........
geposted Fri 20 Mar 15 @ 11:12 am
Are there any other settings I can change??
geposted Tue 24 Mar 15 @ 7:11 am
The next beta build will have it upped a bit more and whilst far from ideal you could always toggle backspin functionality from a button if you wanted.
geposted Tue 24 Mar 15 @ 12:51 pm
Oh nice!!
And I didn't realize I could do that, could elaborate?
geposted Tue 24 Mar 15 @ 1:45 pm
setting 'touchWheelBackspin' ? setting 'touchWheelBackspin' off : setting 'touchWheelBackspin' on
This will toggle the 'touchWheelBackspin' setting.
geposted Tue 24 Mar 15 @ 2:30 pm
Badass!!
Thanks bro!! This will come in handy 😜
geposted Tue 24 Mar 15 @ 3:56 pm
If using on a custom button, then the above would be better as the button would illuminate when on.
The other code will work but doesn't provide the visual feedback. Plus this ones shorter ;-)
geposted Tue 24 Mar 15 @ 4:01 pm
Excellent!!
You fellas never cease to amaze me 🙏 Thanks!
geposted Tue 24 Mar 15 @ 5:36 pm
38%
