Hey, I have a version of Virtual DJ 8.0.2048 and I have a problem with the volume sliders, and exactly what I have them set to 100% in both deck and looks like this:
http://www24.zippyshare.com/v/XlUmAUsm/file.html
Anyone know how to fix it?
geposted Thu 05 Mar 15 @ 8:55 am
2048? We're on 2162 now as beta or2139 as public, update.
geposted Thu 05 Mar 15 @ 9:43 am
I did updates for this device, but the problem is still
geposted Thu 05 Mar 15 @ 11:22 am
So what build are you on?
Are you using hardware?
geposted Thu 05 Mar 15 @ 11:45 am
Looking at the pic, I suspect it might be a skin issue.
What skin is this, where did you get it, have you modified it? Are you using VDJ with a mouse only?
geposted Thu 05 Mar 15 @ 11:50 am
VDJ I use only the mouse, I have the original skin
Nothing has changed my
geposted Thu 05 Mar 15 @ 11:57 am
Go to the interface menu in config, choose the internal (right at the top) and check if the problem persists.
geposted Thu 05 Mar 15 @ 12:20 pm
It did not help, I do not know what to do :(
geposted Thu 05 Mar 15 @ 1:15 pm
You could request some remote assistance from Atomix support.
geposted Thu 05 Mar 15 @ 1:24 pm
You're not helping by not telling us what build you are using.
geposted Thu 05 Mar 15 @ 2:08 pm
My guess is he is using a cracked version Heres what it looks like
geposted Thu 05 Mar 15 @ 2:24 pm
Well that solves that one!
@cyaa09, download the genuine version from here and you won't have any issues.
geposted Thu 05 Mar 15 @ 5:05 pm
I use a version of the 30-day trial djjohnnyrox or so I ask why this is happening
geposted Thu 05 Mar 15 @ 5:09 pm
Post a pic of your login page
geposted Thu 05 Mar 15 @ 5:10 pm
Problem solved, I installed where it was version 7 :( Thank you all for your help :)
geposted Thu 05 Mar 15 @ 5:27 pm
Hmmmmmm
geposted Thu 05 Mar 15 @ 5:56 pm
djjohnnyrox wrote :
Hmmmmmm
I agree completely :-)
geposted Thu 05 Mar 15 @ 6:01 pm
