System freezes and then crashes when going from video back to audio. Windows closes the program out. How do I get this to stop?
geposted Thu 05 Mar 15 @ 8:51 pm
What are you using for the visualization, milkdrop, slideshow, etc.?
geposted Fri 06 Mar 15 @ 12:04 am
Slideshow
geposted Fri 06 Mar 15 @ 12:25 am
So, only slideshow? Maybe you have a bad file in that folder. Try another folder of pictures, and see if it still happens. Are you using the latest public version?
geposted Fri 06 Mar 15 @ 12:31 am
Ok, I'll try that. Yes I'm using the current version
geposted Fri 06 Mar 15 @ 12:34 am
Also try the other options, and make sure they work fine, milkdrop, text, title. Put a mixture of audio and video tracks in automix, and let it run awhile.
geposted Fri 06 Mar 15 @ 12:46 am
By "current" version you mean the public build 2139 ? Can you try with the Beta build 2162 ? Some bugs related to your issue have been fixed if not mistaken.
enable "get beta builds" from either VirtualDJ OPTIONS (Config) or from your Account
geposted Fri 06 Mar 15 @ 2:08 am
My effect tab would close out, not instantly anymore, happens when switching between video and audio a few times.
geposted Fri 06 Mar 15 @ 3:23 pm
