Forum: Old versions
Topic: whats going on with my systeme:(
We need help. Any help would be appreciaited
Issue #1: After playing for about 45 minutes we are experiencing sound drop out, were the sound is crackling
and low. The only way we have foumd to fix the issue, is to pull out the cord from the rca in back of a Numark IDJ3
and then plug it back in, to re-establish the sound. This is an issue because you cant stop playing at a gig because
that's just not proffessional.
Issue # 2:The Pitch in vd7 is sticking and not being recognized all the time, we have to jiggle numerous times for it
to start to work.
Issue #3: As a former technique sl1200 user I notice the pitch control in virtual / IDJ3 is way off compared to my
1200s. Basically you move pitch a little bit and the record jumps way too fast.
This is the system im using: Windows Vista Home
Memory 3 gb System 64 bit
Pentium Dual Core Processor t4200 2.00 ghz
Any help would be appreciated.
geposted Sun 08 Mar 15 @ 6:56 am
#1 sounds like a hardware or connectivity issue - clean contacts and or get new cables
#2 adjust the pitch range to around 8% or 10% and should mimic pretty close a technique sl1200
Windows Vista? Ugh How many background tasks are running, I would be looking at high audio cpu usage,
