Forum: Old versions
Topic: License needed for plugins?
Hey, I'm looking for a way to play lights in sync with an MP3/wav/whatever.
I've been using Freestyler to program the lights but it doesn't have a way to play an MP3. Someone on the Freestyler forum suggested I try Virtual DJ. I see there is an addon that seems to do what I want.
So, I downloaded the program. I consider myself a Home User--described as "If you are not using it professionally, and do not use any professional equipment like a USB DJ controller, or a DJ mixer, then VirtualDJ is FREE."
But looking at the FAQ, I found this: "First, you will need to be a registered licensed user to be able to download additional free skins, effects, samples, etc."
So, for my uses, the program isn't free is it? What is the cheapest version I can buy to get this functionality?
Thanks,
Andy
geposted Sun 08 Mar 15 @ 8:33 am
Some of the addons are available to Home users. The person who creates / uploads the addon decides who to make it available to.
So you are not DJing professionally but you do have DMX lighting just for use at home?
I'm a videographer/video artist. I want to shoot a music video with lights in sync to the music. I really don't need any DJ functionality--I just need to sync the lights to music. I think I found another way to do it--researching that now.
I don't anticipate making any money on this project--just doing it for fun.
So, yes, there is a 'pro' icon on the download page. If I get there a different way, it tells me my license will not allow the download.
Thanks for the reply.
Unfortunately the plugin class used by DMX plugins doesn't actually exist in anything other than a Pro version - even if you could download it, it wouldn't work with the free version.
So, maybe someone should rewrite this: "If you are not using it professionally, and do not use any professional equipment like a USB DJ controller, or a DJ mixer, then VirtualDJ is FREE."
Sucks to waste my time trying to learn to do something when it just isn't an option.
I would consider a DMX interface to be 'professional equipment' personally. It's certainly not something your average non-professional user has or uses at home.
Whatever...
The sentence says 'like a USB DJ controller or a DJ mixer'. A DMX interface has nothing to do with DJing per se.
The sentence is poorly written and misleading.
And I wouldn't consider a $60 controller to be a professional item either.
OK, I'm done venting.
Now you've explained what you're trying to do, I'd suggest approaching it from a different angle.
You clearly don't need DJ software.
As you mention Freestyler, are you aware of this? -> http://www.freestylersupport.com/wiki/sound_2_light
Most DMX lighting is capable of reacting to audio on its own too (via built in mics).
Yes, I've seen it and it looks interesting. But I need hard sync. The music I'm using will not always have a steady beat to pick up on. (I wasn't clear on whether the VDJ setup would do that either but it looked like promising to try.)
OK well what are you using to shoot or edit the video? It should be possible to keep audio and video in sync, either whilst filming or in post.
Presumably you know the tempo (BPM) of the music. If the music has been recorded in a DAW then you could easily use a MIDI "click track" from the DAW to trigger Freestyler.
