Topic: Auto-Mix
when you start using auto mix and try to add songs when its on it always jumps back to the top after you add every song forcing you to have to scroll down again to add the next one at the bottom of the list. This is VERY annoying when the list is long.
geposted Wed 11 Mar 15 @ 8:21 am
I am running the current version of 8 but I've never experienced that with any prior version and I use AM all the time.
joe...
