-get_browsed_song "already played" can be used in queries
-reloop_exit returns true if there is a loop to be relooped
-Fix reading serato crates where parent crate doesn't have content
-fix sampler bug when using sample actions with samples identified by name
-allow relocate on multiple files
geposted Sun 15 Mar 15 @ 2:32 pm
Serato crate reading is worse now.......
VDJ is only reading about half my crates on both PC and Mac.
geposted Mon 16 Mar 15 @ 10:17 pm
Ok, this is a nice function, but for search it opens for each song a new window.
Why we can´t search more songs in a folder, because i moved songs without VDJ in another folder or path.
geposted Tue 17 Mar 15 @ 4:37 am
Batch relocation...
First, thanks for the feature. It selects different folders for different located files and the relocation works.
BUT:
Once you selected like 200 missing files and started the relocation, you can't stop it.
Meaning, you either have to confirm 200 times the relocation window with OK, or press 200 times Cancel.
I think, if you press Cancel once, you shouldn't get the other relocation windows.
Imagin doing that for 1000+ files...
Would be better to leave the loop if Cancel is pressed.
BUT:
geposted Tue 17 Mar 15 @ 5:30 am
PachN wrote :
Batch relocation...
BUT:
BUT:
geposted Tue 17 Mar 15 @ 8:54 am
This kinda goes for most of the features where there's a multiplier. (Scanning for BPM's.)
Once you start it, there no stopping it other than quitting the application which can cause the internal database to become corrupted.
geposted Tue 17 Mar 15 @ 9:01 pm
No, that's not the case. VirtualDj will finish saving the database before it quits...
geposted Wed 18 Mar 15 @ 6:52 am
