Forum: Old versions
Topic: Rhythm Wave Graphic Jerky
The Rhythm Wave appears to be jerky on all my computers. Is there a way to make it scroll smoother? It doesn't seem to matter what skin I use and I tried increasing skin FPS in the settings.
geposted Sun 15 Mar 15 @ 11:35 pm
you forgot one thing, SPECS... what are the spec of your machine that VDJ is running ...
it will get you answers quickly maybe :)
Ahh, yes!
I didn't put specs because it happens on both my machines.... Thought it was a setting I could change... like skin FPS
Laptop:
HP, HDX 18 2.53 q9300 Quad Core EXTREME, 8GB ram, SSDS, 64-bit, Windows 7, Fegorce GT 130
Desktop:
4.0 Ghz
I7-4930K Quad Core 4.0ghz, 16GB ram, SSDS, Windows 8.1, 64-bit (Motherboard - Asus Rampage Black) , Geforce GTX 780
All the other graphics seem to run smooth
