-playlist_add also works for adding files selected in sidelist to playlist
-fix focus during automix not changing just by adding files
-Fix log in window popping up twice on very first start
-More serato crate fixes
-Gemini controller browser support
-Virtual Folder fix when dragging new files from explorer
-Database copy file fix
geposted Wed 18 Mar 15 @ 10:25 am
with this build, karaoke files are stuttering. the music plays fine but the graphics are lagging.. didn't happen in the last build
geposted Thu 19 Mar 15 @ 12:04 am
Just tried playing karaoke and everything seems to be fine from my end.
geposted Thu 19 Mar 15 @ 8:47 am
Karaoke files fine
geposted Thu 19 Mar 15 @ 5:49 pm
Yes!! Thank You for fixing this bug! https://virtualdj.com/forums/195523/VirtualDJ_8_bug-report_Forum/Audio_Settings_Bug_.html
Although it isn't mentioned in the changelog, it seems to be fixed, at least with my setup. Hope it'll stay like this!
Much love
Much love
geposted Fri 20 Mar 15 @ 11:11 am
Not a bug but an annoying behavior: when dropping a file into a virtual folder I'm taken to the virtual folder, this makes for very slow/annoying set preparation. Please can we have the old behavior of remaining in the current folder at the current position after a file has been moved/copied.
geposted Sat 21 Mar 15 @ 10:23 am
@bagpuss drag the Vfolder into the side list and you can add files that way.
geposted Sat 21 Mar 15 @ 10:51 am
