Forum: Old versions
Topic: M-Track Plus (MKII)
I'm looking to replace my External MAY card.. Any thoughts on this one or suggestions for low latency
M-Track Plus (MKII)
Specifications
Mic Inputs 1–2 (balanced XLR)
Frequency Response: 20 Hz – 20 kHz (+/-0.1 dB)
Dynamic Range: 104 dB (A-weighted)
Signal-to-Noise Ratio: 104 dB (1 kHz, +1.4 dBu, A-weighted)
THD+N: 0.003% (1 kHz, +2 dBu input, -0.8 dBFS)
Preamp EIN:
-133 dBu (max gain, 40 Ω source, A-weighted)
-126 dBu (max gain, 150 Ω source, unweighted)
Sensitivity: -53 dBu
Gain Range: 55 dB
Line Inputs 1–2 (balanced 1/4" [6.35 mm] TRS)
THD+N: 0.022% (1 kHz, -1 dBFS)
Sensitivity: -43dBu
Gain Range: 55 dB
Inst Input 1 and 2 (unbalanced 1/4" [6.35 mm] TS)
Sensitivity: -47 dBu
Input Impedance: 1 MΩ
Gain Range: 55 dB
Main Outputs, L and R (impedance-balanced 1/4" [6.35 mm] TRS)
Frequency Response: 20 Hz – 20 kHz (+/-0.3 dB)
Dynamic Range / Signal-to-Noise Ratio: 102 dB (A-weighted)
THD+N: 0.008% (1 kHz, -1 dBFS)
Max Output Level: +2.86 dBu
http://www.m-audio.com/products/view/m-track-plus-mkii#.VQpddI73gaP
geposted Thu 19 Mar 15 @ 12:42 am
