- I can´t use the Display with Deck 3 and Deck 4 with the Nativ mapping.
- Loop Buttons lighting up with different Buttons and function...
- can´t use Filter Touch Button on the Filter Screw/Poti
- Hardware: There is no Sampler Volume Fader -_- but this is a misstake of Numark
geposted Thu 19 Mar 15 @ 2:08 am
Are you sure you re running a build greater than 2174 ..? http://www.virtualdj.com/forums/199180/Hardware_Technical_Support/Numark_NV_-_Version_8_Support.html
Sampler. Volume can be controled too . Take a look at the manual
geposted Fri 20 Mar 15 @ 7:57 am
Version 2177
geposted Tue 24 Mar 15 @ 9:55 am
Sorry, cant reproduce any of the above.
Can you verify that the 3 units are assigned as followed ?
Numark NV Display Left ->Assigned : Automatic (1.3)
Numark NV Display Right ->Assigned : Automatic (2,4)
Numark NV ->Assigned : Automatic (1,2,3,4)
Btw, you can adjust the Sampler Master Volume, if you switch to the SAMPLER mode and use the BEATS knob while the SAMPLER mode button is pressed.
geposted Tue 24 Mar 15 @ 5:11 pm
I dont´t have this controller, i was in Musicstore Cologne (Germany) to check it.
The Reseller ask me, because the mapping with Virtual DJ
geposted Wed 25 Mar 15 @ 10:50 am
