When Djing at my local bar I noticed the right side was not working , I could not load any songs , or even hit play , but the left side was still working . So I had to turn off the Controller and turn it back on , for the rest f the night it worked fine , just wondering what could of caused this problem . Also is there a Way to reboot Virtual DJ without shutting the music down , if that makes any sense . Or if this happens again , what can I do so it does not look like i just went down , and to keep things moving still .
geposted Fri 20 Mar 15 @ 8:22 am
Config - controllers tab , right-click on the controller and choose Reconnect
geposted Fri 20 Mar 15 @ 8:30 am
Thank you !!
geposted Fri 20 Mar 15 @ 8:42 am
