-Improved video engine
-Stutter hot_cue mode now uses last pressed hot_cue
-Improvements to repeat_stop
-repeat_start commands with same identifier now reset
-No mouse-over graphics and tooltips when using touch screen
-Fix hotcuemode play
geposted Sun 22 Mar 15 @ 1:24 pm
whats changed and will it utilize the graphic cards anti-aliasing features?
why have you done this? tool tips are still handy for me even when im using my touch screen.. will things like pressing CPU Meter stop the info tool tip from popping up?
geposted Sun 22 Mar 15 @ 5:55 pm
Since there is nothing really like moving the pointer without clicking for touch-screens, most of the time you'll end up with tool tips on top of buttons/sliders you just used, blocking their view.
Vdj8 used the video card's anti-aliasing since the first release.
geposted Sun 22 Mar 15 @ 11:21 pm
its never worked on AMD HD 5570, AMD HD 6570, Intel i5 HD graphics...
geposted Mon 23 Mar 15 @ 8:52 am
I also would like, to learn what's improved by the Video engine. I'm using only Videos in my sets and that's something that really concerns me :)
geposted Mon 23 Mar 15 @ 9:05 am
Could you post a screenshot where you can see that? (And some specs about the video you are playing and the screen you are displaying it on?)
It sounds unlikely, unless the driver settings have been forced to ultra-low quality or something like that.
The improvements are general updates to the decoders used.
geposted Mon 23 Mar 15 @ 12:18 pm
The truth , I am very impressed with vercion , my cpu consumes only 3% ...congratulations ...
geposted Mon 23 Mar 15 @ 12:21 pm
Why Virtual DJ 8 doesn't run videos (MP4 Video, 1920x1080 Hd, Length 00:01:39, 203MB, frames 29, total bitrate 17065kbps ) and Virtual DJ 7 does?
geposted Mon 23 Mar 15 @ 10:20 pm
expose part of my problem here with the permission of the moderators
sawtooth effect on image
file details
msi gp 70 leopard
Procesador: INTEL Core i5-4200M + HM86 2,5 Ghz.
Chispet: Intel HM86.
Pantalla: 17,3'' FULL HD, 1920 x 1080 píxeles.
Memoria: 8 GB DDR3.
Disco duro: 128gb SSD + 1TB.
Sistema operativo: WINDOWS 7 ULTIMATE
Tarjeta gráfica: NVIDIA GeForce840M, 2GB DDR3.
file details
msi gp 70 leopard
Memoria: 8 GB DDR3.
geposted Mon 23 Mar 15 @ 11:25 pm
@gabycorrea: Try turning MicroFrames off..
Settings: showAdvancedOptions on > Video > MicroFrames
geposted Tue 24 Mar 15 @ 3:09 am
thanks for your advice I'll put into practice and informs him regards
geposted Tue 24 Mar 15 @ 5:13 pm
I only get that if I set videoResampleQuality to high.
So try to set it to medium.
geposted Wed 25 Mar 15 @ 5:51 am
his advice is appreciated but still not working greetings
geposted Wed 25 Mar 15 @ 7:28 pm
I apply its recommendation not work properly
regards
geposted Wed 25 Mar 15 @ 7:32 pm
Still getting BSOD when playing HD videos.... Everytime. Tuesday night i went all night without a crash, but the videos i played as well as the karaoke files weren't in HD. The same HD files play PERFECTLY in VDJ7.4.2. Something is broken in vdj8
geposted Wed 25 Mar 15 @ 7:49 pm
My HP envy has dual video cards. VDJ is EXCLUSIVELY using the Geforce GT 740M
geposted Wed 25 Mar 15 @ 8:00 pm
geposted Wed 25 Mar 15 @ 8:01 pm
geposted Wed 25 Mar 15 @ 8:09 pm
for the record, software cannot cause a bsod... only bad drivers and faulty hardware can...
it might help if you could post a picture of the text on the BSOD, so we can help you figure out the real cause...
geposted Wed 25 Mar 15 @ 9:12 pm
Actually, software can cause a BSOD, device drivers are software. I can also write a small C++ program that corrupts memory register, writes this bad register into the Windows registry, and then then does a re-read of that value. As Windows matures, they are less susceptible to these types of crashes, however give me an IDE and a compiler, and I'll get Windows to BSOD in about 10 minutes.
geposted Wed 25 Mar 15 @ 9:50 pm
