Is possible to create this option ?
Thanks
Thanks
geposted Mon 23 Mar 15 @ 6:51 am
in what way would you like to turn it off?
Ive never seen evidence of it working (not even in the current beta 2185 )
The only option we have in-relation to interlace is here...
Make sure "Show Advanced Options" is ticked
"videoResampleQuality" dose make some change to the way videos appear, if you pause a video and keep changing this opion you may see a bit of difference. (Also try loading an mp3+cgs file and look at the words on screen while changing this option)
In comparison between VirtualDJ and VLC player, the output from VLC is much smoother. I could take some screen shots to compare if needed.
geposted Mon 23 Mar 15 @ 6:22 pm
