Hey I'm trying to develop plugin for virtual dj.
I've looking a lot for example code but found almost nothing good.
I just need full code example of one plugin to understand what to do and how.
I've already develop plugin for winamp but it's seems different in vdj.
I'll appreciate any help.
many thanks, Gal
many thanks, Gal
geposted Sat 28 Mar 15 @ 9:36 am
          Have a deep dig round the V7 effects there's some that include sauce,
I have the sauce for the recent Andj (V8 volume effect) but I'm not sure if it can be shared.
geposted Sat 28 Mar 15 @ 3:07 pm
          I can't help it, I like writing sauce instead of source, Tasty copy+pasta sauce.
    geposted Mon 30 Mar 15 @ 5:15 am
          hey,
I'm trying just to popup meassgabox when the plugin loaded.
class cSaadaPlugin8: public IVdjPlugin8
public:
HRESULT __stdcall OnLoad();
HRESULT __stdcall OnGetPluginInfo(TVdjPluginInfo *infos);
// Custom user-interface
// Fill the HWND or xml/bitmap info in the passed pluginInterface structure, to define your own plugin window
HRESULT VDJ_API OnGetUserInterface(TVdjPluginInterface8 *pluginInterface);
ULONG __stdcall Release();
VDJ_HINSTANCE hInstance;
private:
TVdjPluginInterface8 x;
static void *pObjectje;
// Initialization
class cSaadaPlugin: public IVdjPlugin8
HRESULT VDJ_API DllGetClassObject(const GUID &rclsid,const GUID &riid,void** ppObject)
if (memcmp(&rclsid,&CLSID_VdjPlugin8,sizeof(GUID))==0 && memcmp(&riid,&IID_IVdjPluginBasic8,sizeof(GUID))==0)
*ppObject = new cSaadaPlugin8();
else if (memcmp(&rclsid,&CLSID_VdjPlugin6,sizeof(GUID))==0 && memcmp(&riid,&IID_IVdjPluginBasic,sizeof(GUID))==0)
*ppObject = new cSaadaPlugin();
else
return CLASS_E_CLASSNOTAVAILABLE;
return NO_ERROR;
HRESULT __stdcall cSaadaPlugin8::OnLoad()
pObjectje=this;
MessageBoxA(x.hWnd, "Saada", "configevent", MB_OK);
return S_OK;
HRESULT VDJ_API cSaadaPlugin8::OnGetUserInterface(TVdjPluginInterface8 *pluginInterface)
return S_OK;
HRESULT __stdcall cSaadaPlugin8::OnGetPluginInfo(TVdjPluginInfo *infos)
infos->Author=(char*)"Saada";
infos->PluginName=(char*)"NextSong";
infos->Description=(char*)"Change to world";
infos->Flag=0x00;
return S_OK;
ULONG VDJ_API cSaadaPlugin8::Release()
// Close Server
delete this;
return S_OK;
geposted Thu 02 Apr 15 @ 11:00 am
          Sorry I don't have time right now to trace through your plugin code, but is this any help for you?
Maybe too complicated, but it should give some guide.
https://github.com/leadedge/Spout2/tree/master/VIRTUALDJ
Also :
https://github.com/Syphon/VirtualDJ
Also :
geposted Fri 03 Apr 15 @ 2:37 am
          many tnx!
some how onstart function never called.
// VdjPlugin.cpp : Defines the exported functions for the DLL application.
#include "vdjPlugin8.h"
#include "vdjPlugin.h"
#include "vdjVideo8.h"
#include "VdjOwnPlugin.h"
#include <iostream>
*ppObject = new cSaadaPluginVideo8();
*ppObject = new cSaadaPluginVideo();
else
return NO_ERROR;
cSaadaPluginVideo8::cSaadaPluginVideo8()
// Debug console window so printf works
FILE* pCout;
AllocConsole();
freopen_s(&pCout, "CONOUT$", "w", stdout);
printf("NextUpPlugin\n");
cSaadaPluginVideo8::~cSaadaPluginVideo8()
HRESULT VDJ_API cSaadaPluginVideo8::OnLoad()
return NO_ERROR;
HRESULT __stdcall cSaadaPluginVideo8::OnGetPluginInfo(TVdjPluginInfo8 *infos)
MessageBoxA(x.hWnd, "bbaa", "configevent", MB_OK);
printf("GetPluginInfo()\n");
infos->Author=(char*)"aa";
infos->Version= (char*) "v1.0";
infos->Flags=0x00;
infos->Bitmap = NULL;
printf("GetPluginInfo123()\n");
return NO_ERROR;
HRESULT VDJ_API cSaadaPluginVideo8::OnStart()
printf("OnStart()\n");
return NO_ERROR;
HRESULT VDJ_API cSaadaPluginVideo8::OnStop()
printf("OnStop()\n");
//Create Server
return NO_ERROR;
HRESULT VDJ_API cSaadaPluginVideo8::OnDraw()
printf("OnDraw\n");
DrawDeck();
return NO_ERROR;
ULONG VDJ_API cSaadaPluginVideo8::Release()
// Close Server
printf("Release\n");
delete this;
return NO_ERROR;
geposted Tue 07 Apr 15 @ 12:26 pm
          Is that possible to control the playlist by plugin?
I need to get the songs and their time and play one of them..
there is any way to do this from plugin?
geposted Tue 07 Apr 15 @ 1:06 pm
          You'll have to be clearer as to what it is you actually want to do.
What playlist?
What time?
    What playlist?
What time?
geposted Wed 08 Apr 15 @ 7:54 pm
Quote :
No, it won't be - you've told VDJ to instantiate your new plugin instance when the IID is IID_IVdjPluginBasic8. If you're writing a video effect (your class declaration is missing so I can't see what class you have derived from) then you need to check for the IID for video effects - IID_IVdjPluginVideoFx8.
geposted Wed 08 Apr 15 @ 7:58 pm
          the class declaration, I used video plugin because the general plugin didn't works at start.. and I didn't found a way to active the plugin manually.
What I'm trying to do is the send all the songs at the playlist (automix) and the length of each song to a server, and the sever could play each one.
At the api there is nothing like this, there is any other option?
many tnX
many tnX
class cSaadaPluginVideo8 : public IVdjPluginVideoFx8
public:
~cSaadaPluginVideo8();
HRESULT VDJ_API OnLoad();
HRESULT VDJ_API OnGetPluginInfo(TVdjPluginInfo8 *infos);
HRESULT VDJ_API OnStart();
HRESULT VDJ_API OnStop();
HRESULT VDJ_API OnDraw();
ULONG VDJ_API Release();
private:
class cSaadaPluginVideo : public IVdjPluginVideoFx8
geposted Fri 10 Apr 15 @ 9:34 am
          In your DllGetClassObject you aren't checking for the IID of a video plugin, you are checking for a basic plugin instead.
Only pro versions can use plugins declared against the base class btw.
geposted Fri 10 Apr 15 @ 8:55 pm
          Please an example below:
http://www.virtualdj.com/wiki/Plugins_SDKv8_Example.html
geposted Sat 11 Apr 15 @ 7:57 am
          Really? only pro version can run a base plugin.. good to know thank you.
Is there any way to get the songs name from the automix playlist?
geposted Wed 15 Apr 15 @ 4:26 pm
          A second example for an audio plugin:
http://www.virtualdj.com/wiki/Plugins_SDKv8_Example2.html
geposted Thu 16 Apr 15 @ 5:58 pm
          A new example with skin interface
http://www.virtualdj.com/wiki/Plugins_SDKv8_Example4.html
geposted Wed 22 Apr 15 @ 4:57 pm
          Plugins with skins, oh my. Time to convert some caffeine and swearing into code.
    geposted Wed 22 Apr 15 @ 6:27 pm
          Much appreciated, as may examples as possible are welcome.
*Edit also could you please UL the png for example 4, to save a bit of effort?
geposted Thu 23 Apr 15 @ 8:17 am
Example has a couple of problems to compile
MyPlugin8.cpp & MyPlugin8.h both need,
#include "Stdafx.h"
Also line 17, MyPlugin8.cpp, deleting the 0 then it will compile.
'IVdjPlugin8::DeclareParameterButton' : function does not take 5 arguments
geposted Thu 23 Apr 15 @ 12:07 pm
          Request a example of the basic plugin doing something, setting a variable from a dial, querying something, baby steps.  I'm sure it's all there in the original example, just that there's a lot to take in.
    geposted Thu 23 Apr 15 @ 3:19 pm
#include "Stdafx.h"
#include "Stdafx.h"
code updated for vdjPlugin8.h => (float) parameterSize
I had another SDK8 more customized ;-)
code updated for MyPlugin8.cpp to remove 0
geposted Thu 23 Apr 15 @ 4:38 pm
