Hi guys
I have a denon mc6000 (just purchased second hand), a MacBook pro and am running VDJ PRO 7.4.
I am only wanting to run two deck mode and have the following setup for the sound - inputs = line ins, outputs = headphones(master chan 1&2/headphones chan 3&4, 4 in/4 out card = dn-mc6000.
The setup on the mc6000 is set to Mac with the mixing mode on pc. This giving me output on channels 1&4 which I'm happy with.
The issues I have are -
1. Auto gain on the VDJ is not working. I'm having to adjust for every track
2. The fx are not reacting and have caused the software to crash (not every time)
I basically just plugged the denon unit into the Mac and turned on VDJ so haven't dowmload any files etc from denon.
Is there a recommend mapper file for the controller?
Any help and input is really appreciated
Thanks
Iain
Thanks
Iain
geposted Sun 29 Mar 15 @ 3:22 pm
Hi, I noticed nobody ever answered? I HAD THE same exact problem and same exact set up...NOW the latest is they tell me it because VD7 is "old" ad it is not up to date therefore the gain problems will not be fixed unless I use 8...any answer to you? Thanks, just cuious
geposted Sat 29 Aug 15 @ 9:51 pm
