I have started using VDJ 8. When you open a music folder the files you have played do not stay at the top not like when I was using VDJ 7. Basically I want my played files to stay at the top of the folder when I open it
geposted Mon 30 Mar 15 @ 5:41 pm
How is your setting in Options "Keep Sort Order " ?
You can set this to YES and open another field in the track browser collum called last play.
If you sort it once it will keep the order. Works fine here.
geposted Tue 31 Mar 15 @ 4:37 am
