Hi,
Was trying to use the SL3 tonight at a spot with decks/interface already set up and everything looks correct but im getting tone output through the mixer and not the music. Any ideas? Signal cds are playing the tracks on the decks so its picking it up, just the output is tone, not music. used default settings for the sl3 of channels 3/4 & 5/6 for inputs/outputs
geposted Sat 04 Apr 15 @ 8:24 pm
You will probably need to mute the inputs of the SL so that they dont output directly to the outputs
What exactly are the connections that you have done and your audio configuration ?
geposted Sun 05 Apr 15 @ 12:49 am
Well its installed at the location but it looks like standard cdj 1 inputs to channels 3/4 and cdj 2 to 5/6. Outputs the same #1 3/4 and #2 5/6 to the mixer.
Vdj settings are
Deck 1 - sl3 output 3/4
Deck 2 - sl3 output 5/6
Timecode 1 - sl3 input 3/4
Timecode 2 - sl3 input 5/6
Used the default settings vdj set when it detected the sl3
Vdj settings are
geposted Sat 11 Apr 15 @ 6:45 am
There needs to be an update to VDJ 8 that automatically switches the SL3 to use audio from the program and not THRU which is what is happening by default it seems and why Im getting signal tone from the CDs. The control works perfectly but getting signal tone which means the program's default settings are not switching the SL3 from Thru to use VDJ audio. This may be a PC only issue as I know a Mac user who didnt have the issue but with same settings.
geposted Sat 11 Apr 15 @ 8:00 pm
I am having that same tone issue when using SL3 with VDJ but not with SL2, my SL2 work fine with no problem when connected to PC. I have figured out a way to get SL3 working with VDJ8 and thats by first launching Serato DJ with SL3 box connected, load and play tracks on both decks. Close Serato DJ and launch VDJ , After doing that VDJ works fine with SL3 , no problem with software. Does anyone knows how to fix this issue?????????????????? I would like to get SL3 and VDJ working without going through this crazy process.
PLEASE HELP!!!
PLEASE HELP!!!
geposted Mon 31 Aug 15 @ 2:48 am
Can you do this test please ?
Open VirtualDJ , use whatever sound setup you need to and close.
Open the SL3 Utility Panel and take a screenshot of all the available tabs.
Open Serato load 2 tracks and close.
Now open the SL3 Utility and compare the settings. Probably Serato is changing/setting some specific change which by default is different ?
Are you on Mac or Windows ?
Is the SL3 the "default" sound card for your OS ?
geposted Mon 31 Aug 15 @ 4:12 am
any update on this?
geposted Mon 04 Jun 18 @ 8:52 am
Not sure about the SL3, but the SL4 seems to have THRU switches in Control Panel, which for TC they should be turned off
https://dj.rane.com/files/products/sl4controlpanel.png
SL3 Setup info https://www.rane.com/pdf/sl3_manual_dj.pdf Check the Outputs in the Control panel, they should be at USB
Perhaps you can post screenshots here of what you get in the Control Panel of SL3 and get more help on next steps.
geposted Mon 04 Jun 18 @ 11:29 am
Go into your sound card properties click USB instead of analog on both channels
geposted Tue 20 Apr 21 @ 2:04 am
