Hello everybody, I been using vdj since the version 4 was out. Well now that the vdj 8 been out to upgrade I have one problem, I am trying to remove my sound effects from the plugging folder, and make a new folder and put my effects that I use more. but I don't know if there is a way to delete/remove the effects files without then coming back everytime I open the vdj8.
Thank you in advance.
geposted Mon 06 Apr 15 @ 6:48 pm
No the native V8 effects are fixed.
geposted Tue 07 Apr 15 @ 1:50 pm
basically what i want to do is clone the my effects config on all decks so there all the same and i dont have to adjust each one for each deck?
geposted Tue 19 May 15 @ 11:45 am
Things have changed on a recent update, now you can move native FX to folders, from FX select drop down.
As for all FX being the same,
When you open an FX (on any deck) for the first time, it reads the ini, if you change the dials and that is the only instance of that FX in memory on close down the new config is wrote to the ini, if you have more than 1 instance of an FX in memory then the ini isn't updated (as which one should V8 copy?)
geposted Tue 19 May 15 @ 1:20 pm
