as the funky picture shows, i was getting the text from the skin showing in the video out, scrolling towards the foreground.
Is this a particular milkdrop file that can do this or did something go wrong?
ive managed to see this twice in same session..
im using virtualdj 8 build 2195.964
Windows 8.1, i5 16gb 120 ssd etc
Notes: pressing the cog for milkdrop in this session dosent alter the running instance of MD, rather just controls the 2nd instance that i can invoke by pressing the video effect button..
This text seems to be coming from the info pane of the browser.
geposted Thu 09 Apr 15 @ 4:45 pm
also to point out im using AMD HD 5570 1mb graphics with latest drivers..
another screen grab..
geposted Thu 09 Apr 15 @ 4:55 pm
Looks like a mess bro..
geposted Sun 12 Apr 15 @ 8:34 pm
Then you were pressing the wrong cog ;)
No idea what would have caused the above unfortunately.
geposted Mon 13 Apr 15 @ 9:13 am
ive found a command for custom button to address the visual only iteration..
effect_show_gui 'audioonlyvisualisation' 1
or could just change the first part to effect_button, but i wanna get the names of any milkdrops i wanna remove.. :)
In the above screenshots, the 1st one had the text from the info pane scrolling forwards and 2nd one was a kaleidoscope effect..
i've never seen it previous and haven't seen it since either...
geposted Mon 13 Apr 15 @ 10:10 am
