A REQUEST
I want to be able to set a playback BPM for "each track" in a play list and when the play list is saved the BPM's for each track are remembered and played back at that rate when that play list is reloaded.
( we use VirtualDJ for Ballroom dance practice and monthly dances and it would be great to be able to set the replay BPM for each track to suit our novice dancers who struggle to keep up with the steps at the tracks original BPM.)
Thanks - worked that one out - but unfortunately it doesn't provide the solution I need - I need to adjust each track to a specific BPM but the starting BPM of each track is different and the target BPMs are all different depending on dance type.
The best solution for me would be to have the required BPM saved for each track as part of the play list - as this may not be within the compatibility for play lists to be transferred to other apps ( iTunes reads your play lists but AFAIK iTunes can't remember BPM ) it may require a separate BPM list to be written to match each play list name.
David
geposted Tue 14 Apr 15 @ 2:42 am
