Hi, curious shutdown on last Fridays gig during startup.
My gig followed 4 live rock bands, club was heaving and it was a mad rush to setup. Started the laptop, started VDJ then the MC6000 Mk2 controller,
loaded and played the first song which subsequently caused Crash Guard to pop up and VDJ closed, luckily it was the first one so the crowd just thought
it was part of the 'testing'. Could you please check the cause in your logs, suspect it was something to do with starting so quick.
After the reload, everything was normal for the next 7 hours or so.
Also, the video monitors were all showing a small boxed video instead of full screen, the force full video switch is on (1) , could get full screen whatever I tried, all
parameters were as they have been for months. This was the first gig since I downloaded new (non beta) software.
Regards
Bill
Regards
Bill
geposted Tue 14 Apr 15 @ 7:56 am
