Forum: Beta Builds Regression Bugs
Topic: BUILD 2206
-Fix regression copy/move tooltips from b2204
-Fix word wrap on action description on mac
-Fix VDJScript documentation url on mac
-Fix change log not appearing on mac
-Improved checking of moved files for Virtual Folders
geposted Fri 17 Apr 15 @ 5:33 am
Conflicts with slideshow effect, changing folders, loops and photos, malfunctioning ...
On Mac o windows?
Last Night I Play with Build 2206 - Beta
Macbook Pro Retina - Yosemite - DDJ SX 2 - Video - Audio - Visuals -
8 Hours and it Runs Perfekt !!!
Same is perfect!!!!!! No complain with my rmx with timecode playing videos and samples and everything worrking ,...
On Mac o windows?
windows...
Top bumetro mater , shuts down ...
skin is frozen , after disconnecting vga video ...
Never do that while you have virtual dj open ,this kind a action. Is normal it's no recomend it
Mac OSX Mavericks
with Combat Mirror Skin
at first, i load a track on the "not playing Deck" and hear two playing songs -> the playing music and the other not playing Deck on headphone, without to push the Play button. The song playing automatic on the Prelisteing Player. So i change to a "Dennyo"Skin and stopped this prelisting Player, after this, i change the skin back to Combat Mirror.
After this, it was perfect. But what was wrong?
What skin do you use ?
Seems the Net Search has stopped working again.
Netsearch (audio) is working from my end.
problem with skin, always shows gain 1.5 at any skin
Hi. I used the 2206 beta last sunday 19 th. Karaoke. Videos and music . 7 hours. For pc . Everything fine. Just an issue with the sbdj showlogo8. I cant turn it off.
Now is ok.
